350 lt1
350 lt1
i'm wanting to swap my 305 tbi for a 350 lt1 and i'm just curious as to about how much its gonna cost. should i go tpi or stay tbi im not wanting to go over $2000 for the motor and swap. i plan on putting some money into after a few months. wheres a good preferably CHEAP place to get a rebuilt or new lt1 and whats the cost difference between new and rebuilt
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
You might come close if you can get the engine ecm and harness for 1k.
You have to remember that all the little things ad up.
I have close to 5k in my swap. Its not stock however.
This only applies if you plan on doing the work yourself.
I spent 3000$ Canadian on this swap, if you want to do it, keep the real fuel injection system for it, Gm miniram ....that's the way to go ! if you install a tpi or TBI it will restric the amount of horse power that beast is making. I can help you with ANYTHING you want to know, if you're good you can do it on a 2000$ budget ..., you'll also have to make your own wiring harness, motor mount, fuel lines, ps lines, rad hoses and all the littles details ...
it took me 8 days of hard work and tool trowing to be able to start the engine and hear it's magical sound. I did it on my own, no help, fairly easy if you know a little mecanic. , that was my first swap ...I'm 19 years old
To finish the project completly it took me about about 3 weeks working on and off on this
The result is perhaps NICE
Car: 1985 Camaro Z28
Engine: Caprice LT1
I'm doing the same swap into my 1985 Camaro.
I bought a 95 Caprice cop car at an auction which had an multiport injection 350 in it. Costed 2500 canadian for the whole car. Has some nice ABS disc brakes on it too.
In order to run the LT1 setup you WILL have to use the LT1 Injection, or get a carbed intake from GM performance. The LT1's used reverse cooling through out the entire motor I think tarting through the heads and down the block, verses the L98's start from the block and up through the heads. There is just no way around it.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
