OEM TPI Comatibility
Old Oct 6, 2018 | 02:50 PM
scorpiusx's Avatar
Car: 1985 IROC Z
Engine: 305TPI (LB9)
Transmission: TCI 700R4
I was wondering if the OEM TPI system on my '85 IROC Z (305 LB9 motor) would supply enough fuel to a 383 crate motor? Would the intake manifold line up and bolt onto the 383 block?? I would appreciate any info if anyone ever performed this setup. Thank you...Joe
Old Oct 6, 2018 | 04:28 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: OEM TPI Comatibility
The intake will bolt to a 383 block. But in order to use the 383's power you would need to upgrade it. Your stock fuel system needs a bump as well. Larger injectors an adjustable fuel pressure regulator for tuning and a larger fuel pump. To help it breath headers and larger runners and a ported manifold will help also.
Old Oct 7, 2018 | 09:52 AM
scorpiusx's Avatar
Car: 1985 IROC Z
Oops! What I meant to ask is weather the stock manifold will line up with and bolt onto the Dart SHP Aluminum cylinder heads that come with the 383 crate motor?
MikeDwhoROCZImports
Exterior Parts for Sale
Aug 6, 2011 09:27 AM
theMAGICALheat
Sep 11, 2008 11:34 PM
Anoying Eric
Oct 3, 2006 01:09 AM
