cruise control
Old Feb 7, 2019 | 11:14 AM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
cruise control
I want to know when I swap my 2.8 for a 350 with wire harness and e.c.m from donor car,does donor car have to have cruise control for my cruise to work after swap?If there is info on this site on this topic,could someone point me to the link,Thanks
Old Feb 7, 2019 | 12:08 PM
Drew's Avatar
Re: cruise control
Generally speaking, it shouldn't matter. The sensor that drives the cruise control is also used by the EFI, and all the cruise wiring is in the dash harness or the CC harness. So at least in theory, you won't be changing anything related to the CC system.
Old Feb 7, 2019 | 12:57 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: cruise control
I would if you could grab the cruise control box, and the vacuum ball, wiring harness. The cruise on these cars is a separate wiring harness. There is a module in the passenger dash I would also grab. However I'm like 90% sure your 2.8 cruise will carry over... but if you have access to the donor car why not grab the parts to be safe.
Old Feb 7, 2019 | 10:16 PM
Engine: sbc 350
Re: cruise control
Thanks guys.I cant get anything from "donor"vehicle because the guy only wants to sell me the rebuilt engine,wire harness and ecm.All this is from an 87 Camaro and he is going to install L.S 3 engine.
mmadden55
Oct 21, 2009 06:17 PM
gixxer92
Mid-West Region
Oct 6, 2005 09:56 PM
89ProchargedROC
Feb 19, 2003 07:48 PM
GTA91
Feb 25, 2001 04:23 PM
