connecting rods 305-355 swap
Old Jan 9, 2002 | 12:09 PM
johndo1707's Avatar
hi, i am building a 355 tpi engine and i currently have a 305. i will be using the crank from the 305 to build the 355 except it will be balance properly. i was wondering if i can do the same thing with the connecting rods or do i have to buy new ones???? thanks a lot
Old Jan 9, 2002 | 01:35 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
IIRC, the common 305 conrods are thinner and weaker. There are a few that are the same as 350's, but I dunno which ones.
If my damn scanner had an updated driver for WindowsXP then I could scan a pic for ya. Sorry
If you take a trip to the local machine shop, they can show you the two side by side, and they'll probably sell you the 350 rods for dirt cheap.
If you're gonna have it all balanced, then there won't be a problem with using 350 rods on a 305 crank.
AJ
Old Jan 9, 2002 | 01:55 PM
johndo1707's Avatar
yeah, i was htikning that i should just buy the 350 rods and do it right the first time so there won't be a second time,lol. thanks alot
BRoss99
Aug 10, 2025 05:08 PM
Reborn756
Sep 4, 2015 03:42 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
theurge
Aug 21, 2015 12:46 PM
