ZZ MOTORS AND COMPRESSION RATIO
Old Sep 1, 2019 | 10:13 PM
BHR's Avatar
BHR
Little puzzled here anyone know why the zz5 and zz6 motors are 9.72 ratio and the zz385, zz430, sp350 are 9.6? From what i can tell they have the same pistons, heads and head gaskets. A sp350 with cam and rocker upgrades on paper should make over 430HP and be the cheapest new GM long block compared to the zz6, would a thinner head gasket also be beneficial?
https://www.chevrolet.com/performanc...sp350-385-base
https://www.chevrolet.com/performanc...gines/zz6-base
Old Sep 1, 2019 | 10:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: ZZ MOTORS AND COMPRESSION RATIO
Probably an error in their information unless they dont use same gaskets or if the piston to deck height is different but i doubt that
zz6 does have a single plane intake and better rocker arms but not sure if thats all worth the extra cost
cam and single plane on the sp350 would haul the mail. Or even a performer rpm ported abit.
Old Sep 2, 2019 | 02:07 PM
BHR's Avatar
BHR
the only diff in part number i can find is the heads but there both listed as 62cc so who knows have to make some call to se what the people who sell these say about it
would be selling valve covers intake manifold water pump dizzy reusing camaro efi with a stealth of super ram, corvette aluminum water pump and magnesium valve covers
Sooner
May 2, 2009 01:40 PM
IROCThe5.7L
Mar 19, 2009 03:43 PM
BOSS 357
Aug 15, 2008 04:06 PM
davep_96
Apr 16, 2008 04:58 PM
Phatfiddler
Aug 27, 2007 02:30 PM
