HELP! 305-350
Old Jan 5, 2021 | 09:41 AM
Blackbetty1982's Avatar
Car: 1982 Camaro Z28
Engine: 350 SBC
HELP! 305-350
Hello, Ive swapped out my old 305 for a 350, i have not a single clue on how to wire the motor up to run, i did and A/C delete so that whole wiring thing is already figured out, but the rest im lost on, its my first engine swap ive ever done and would like some help. please and thank you!
Old Jan 5, 2021 | 09:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: HELP! 305-350
Was this ccc ? Man your distributor is indexed way off
Old Jan 5, 2021 | 10:01 AM
Engine: 350 SBC
Re: HELP! 305-350
distributor is out right now i was thinking i was close to getting it running and took it out to prime the oil pump and make sure everything was lubricated, also i am not on a unlimited budget and just want to get it running so i have something to cruise around in from time to time while i save for the parts i want so yes there is rusty old 305 accessories on this block
Old Jan 5, 2021 | 11:49 AM
Engine: Lb9
Transmission: M20
Re: HELP! 305-350
All you need to hook up electrically is the power to the hei and alternator. Starter wires
Old Jan 5, 2021 | 12:10 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: HELP! 305-350
Looks like you missed connecting a ground strap at the back of the block and at the front. Also no clamp on the heater hose that goes to the top of the water pump. Also you need to wire the alternator.
If you pulled the old motor, remember to mark everything before disconnecting next time.
Old Jan 6, 2021 | 07:21 AM
Engine: 350 SBC
Re: HELP! 305-350
Thank you guys like i said i am brand new to any of this so this helps a lot any other tips just let me know
Old Feb 17, 2021 | 11:04 AM
GBousley's Avatar
Car: 1992 Firebird base
Engine: 305 TBI
Transmission: 700r4 / 4l60
Axle/Gears: stock
Re: HELP! 305-350
Hey! Glad to see another doing the swap. I'm a few months out from making the swap as well on my 92 bird. If you don't mind when you're all done come write up how it went, mistakes, resolutions, and learning points for those of us about to do the same. Would appreciate it!
89Camaro350
Apr 23, 2007 10:30 AM
