86 Trans Am triton 6.8 swap
I know I know why would you want to swap in a Ford v10?, well why not? I understand that it would be more practical to 350 swap or ls swap it but that’s overdone. My question is aside from the Ford to Pontiac mounting differences how difficult would it be to shoehorn a 413 into the car?
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: 86 Trans Am triton 6.8 swap
V10 from the Ford is a terrible engine. An LS Swap is proven, straightforward, and will make so much more power in virtually all variants. Just sayin.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I guess just about anything is possible with the right tools and materials on hand for a weird "dare to be different" swap,but for something that would be nice to drive,a big v-10 truck engine in a midsize GT coupe is a "wild hare"chase I would forget about
With OHC heads,that Ford is probably too wide and tall-I'll look under hood of my '99 f350 v-10 and have a look sometime
If you want Ford,stick a 351w/c6 in there.
If you want Ford,stick a 351w/c6 in there. Supreme Member
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I don't know in what condition your TA might currently be, but by hacking it up to install an oddball engine, you'll pretty much be destroying the car's value.
If you must swap-in a V10, (and you either own a pro shop or else have $$$ to burn) at least go with a Mopar/Viper engine; that Ford Triton is a POS, and died an ugly production death buried under a mountain of spark plug and cylinder head problems.
A couple of reasons 'why not:'
Car: 1986 IROC Z
Engine: 5.0 TPI
Good luck with your swap; take plenty of pics.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You won't get any love here because frankly, how would anyone know? These crazy swaps come up all the time and they always go no where, because they are silly. At the end of the day, the secret ingredient is money and determination, both of which are immediately abandoned after the first obstacle is encountered. It's a waste of time to even dignify these conversations with a response.
I’m not asking for step by step instructions bud and I definitely don’t remember asking for your opinion I’m asking the people who have actually shoved big *** engines into these cars because I know people have shoehorned bigger motors than a 413 into these cars
Car: '90 RS
Engine: 377 LSX
You literally asked for our opinion. You're going to need to do a ton of fab work and custom work that only you can figure out. There is a snow ***** chance in hell that someone has done this on this site. I'm not trying to be mean, these threads come up all the time and NONE of them ever come to fruition. I hope you prove us wrong.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
while personally I would never put a non GM engine into any of my 3rd gens, if you are bound and determine to do this, you can do some quick homework and see how difficult it will be
- get a comparison dimensional information between your basic SBC or LS to the Ford... you are likely to see that the length and width are going to give you some challenges, looking at the dimensions of the difference and then looking at your 3rd gen engine bay for reference you can quickly judge the issue
- you are going to have to think about a transmission, using what came with the ford is also going to probably be an issue for the tunnel. trying to mate a tremec or GM automatic you are going to need to explore is there even a bellhousing, etc that would likely work.
- since the engine is wider and longer you need to think about exhaust, this likely is going to require some creativity and likely either by you or someone else something custom and therefore cost some $, but again look at some pics with measurements and then your car you have
- how are you thinking about controlling the engine? you better check that you or someone else has the ability to either tune the original ECM and turn it and its harness into a stand alone or you are confident you can utilize a Holley , etc
- what are you going to do with front end accessories... likely what is on it is not going to be favorable, but again measure and look
with enough time and money anything can be done... i personally would not consider this a good use of time and money, but it is a free country and that is your choice... my ending comment would be just do some quick homework as i pointed out above for yourself and then the answer on pursuing this or not will be likely more obvious to you... good luck
Car: '84 TRANS AM
Engine: 5.7L SBC
Transmission: TH700R4
Axle/Gears: Stock 3.73 Posi
Car: '84 TRANS AM
Engine: 5.7L SBC
Here's a YT video from the guy who built it. Great place to go if you have questions!
Transmission: T-5, TH350, T-5
I haven’t been in the right place to start this project yet but I have come across this fella that’s doing the same thing to a 3rd gen Camaro https://youtube.com/c/Nodarperformance
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Unless a car is a "holy grail" collectors item, I'm all for sticking different brands of engines in it. That is what hot-rodding is all about.
But in this case, a V-10 is not going to fit. It can be almost guaranteed that no one here has done it...
If you are Only after the 6.8L Displacement...
It is easy enough today, to just build a 6.8L LSx Engine!
