FRAME REINFORCEMENT
Old Oct 14, 2021 | 09:08 PM
prairieboy's Avatar
Car: '86 Camaro Berlinetta
Engine: 2.8L V6
Transmission: 5 Speed Manual
FRAME REINFORCEMENT
With the following plans below I'm genuinely worried about twisting the frame what can I do other than connectors?
From the last time I posted on here I have done a large ammount of research my current plan is to buy a used LQ4 to swap in I have found someone to fabricate me some mounts for engine and trans. Going to buy a haltech standalone ecu, fully forged internals, t-57 trans, bore it 30 over with a 4 inch stroke to bring it from a 6.0 to a 6.7, boost it. Goal is 800-1000 at the crank this leaves questions however.
Old Oct 14, 2021 | 10:00 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: FRAME REINFORCEMENT
Yea it's simple, weld an 8 point cage in there. Once your done that throw a good fuel system in there then a 9" or s60 rear end
Old Oct 14, 2021 | 10:50 PM
prairieboy's Avatar
Engine: 2.8L V6
thanks man will definitely look at this
Old Oct 14, 2021 | 11:09 PM
thatsupnow's Avatar
A word of caution tho when going for big power, costs can and probably will balloon out of control. I did my entire drivetrain over the last 5 years and some other stuff and I'm sitting around $35,000 so far. I got it running last month and there's still body and paint to deal with
Old Oct 15, 2021 | 06:01 PM
vorteciroc's Avatar
Top Answer: 1
The Cage should be tied into Sub-Frame Connectors.
Both styles of Sub-Frame Connectors (tied together) and a 6 or 8-Point Cage tied into the Sub-Frame System works very well.
I have done a few Dozen F-Bodies this way (as well as Cages for faster safety regulations).
Old Oct 16, 2021 | 11:17 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I'm just wanting to put something on there - subframe connectors that is, that works with a factory setup, single exhaust, factory cats, and no clanking on anything when driving down the road. have any experience with something that works? not needing super high performance, just want to stiff things up a bit.
Old Oct 16, 2021 | 06:14 PM
vorteciroc's Avatar
Top Answer: 1
The Sub-Frame Connectors that run along the Body Pinch Weld (out-board Connectors), will work for you.
Spohn and others offer them.
I am not certain, but I believe that you would not want to use the Alston style, (in-board Connectors) as they may interfere with exhaust.
rs89todd
Apr 24, 2011 09:10 AM
chevyracingrox
Apr 25, 2010 10:20 AM
Xophertony
Feb 16, 2004 08:42 PM
StylnCamaro
Oct 17, 2002 01:16 PM
