Differences in Gen II LT1 Idler Pulleys
Old Jan 4, 2022 | 09:23 AM
JMarchione's Avatar
Car: 1985 Camaro Z28
Engine: 5.3 LS
Axle/Gears: 4.11
Good morning,
I am working on an LT1 swap, and since the engine came with the vehicle, I'm not sure exactly what model year it is or what car it came out of.
I'm fairly certain it is out of a Corvette from either 95 or 96 but I'm not 100% sure.
I'm having trouble with the accessory belt drive. The alternator pulley, P/S pulley, and A/C pulley line up with the crankshaft pulley, but the idler pulley is recessed about 1/2".
I'm assuming that I have the wrong pulley, maybe I have a Corvette idler pulley and everything else is for Camaro?
Is anyone aware of any different pulley offsets like how the Gen III LS series of engines has different pulley offsets for truck engines, F bodies, and Corvettes?
The only issue I have is with the idler pulley, everything else lines up.
Thanks in advance!
Old Jan 4, 2022 | 10:06 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Differences in Gen II LT1 Idler Pulleys
Is this just a pulley with a bearing? Some of these have a bushing inside the bearing bore and has a thick shoulder on the back side that spaces it out. Maybe not on this one but worth a look.
88RS
Dec 28, 2020 07:32 AM
Procharged GTA
Feb 18, 2008 09:28 PM
