LT1 crank pulley on gen 1 sbc
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Can I use this LT1 underdrive pulley on a gen 1 sbc with 88-92 f-body accessory drive?
https://www.ebay.com/itm/Pulley-Cran...ycmBSsfo2#rwid
In searching it sounds like one hole is offset 5° on the LT1 from a gen 1, but that's all I saw in searching...
Would it work if I elongated one hole?
Thanks.
Thanks.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: LT1 crank pulley on gen 1 sbc
no,LT1 crank damper/pulley will not work-belt grooves are way too far back at the very least...Nobody makes underdrive pulley for 88-92 anymore?
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Thanks for confirming that for me. Yeah I see ASP 540800, which is just the crank pulley. $104 is a hard pill to swallow, even if it's made in America. I have a 253 amp AD244 alternator, so I'm not concerned with trying to speed it back up. Everything else I see has the alternator pulley I don't want to pay for.
Car: 91 z28
Engine: 305 tpi
Transmission: t5
I just found this aluminum set for like $63:
https://www.ebay.com/itm/SB-CAMARO-3...0AAOSw4jJdg~eZ
I just measured though, and the crank pulley is very close in size to factory so scratch this one too...
Engine: 4++,350 & 305 CIs
Don't use the large alt pulleys on the street. It won't charge well.
In fact, use a smaller than factory GM pulley, I got a few from fox mustangs that are smaller.
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 91 z28
Engine: 305 tpi
Transmission: t5
This doesn't make any sense, and this didn't show up in my search of Summit the first time... But Auto Specialties 540801 costs $101.99 and includes the alternator pulley with the crank pulley. 540800 is only the crank pulley and costs $103.99. I don't understand it, but I think it's clear which one to buy.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I think I still have a March underdrive crank pulley left in my parts bin if you are interested.
It is for a L98
It is for a L98
MrDude_1
Jan 22, 2004 02:11 PM
