question on balancer
Old Mar 2, 2004 | 02:04 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I am planting an LT1 into my 3rd gen.. im trying to reuse the 3rd gen accessories to keep the costs down.. except the acc stick out about 1 pulley too far..
How interchangable are the Balancers? My idea.. use 3rd gen 305 balancer.. on LT1. that will push balancer out what is needed.. perhaps further.. then shim the acc bracket to line up.. But I understand that playing with balancers is a no no? What do I need to know about em?
Old Mar 2, 2004 | 02:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: question on balancer
They are not interchanagable and the LT1 is a two piece unit. You can fab some spacers for your accessory bracket to push it out the right length. There is one board member here who has done that succesfully. I am not quite sure how he did it but I geuss it worked great. Check out the threads in this forum for LT1 accessories on a 3rd gen.
Old Mar 2, 2004 | 04:27 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i can do the spacers fine but the balancer is behind the acc .. grrrr..
Old Mar 2, 2004 | 09:15 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i don't know if this will work yet.. haven't made it to the garage tonight.. What if i unbolted pulley from 305tpi and put it on the lt1 balancer? would the extra weight on the crank mess anything up?
Old Mar 2, 2004 | 09:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am pretty sure that it will not bolt up. Even if it did I bet it would still not be on the same plane as the rest of your accessories.
Old Mar 2, 2004 | 10:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A friend of mine who works in a shop has looked into that. IIRC, the standard SBC pulley bolt pattern is 3 bolts, 120° apart, evenly spaced. The LT1 pulley, I THINK, has 1 bolt ofset like 5° or so. Unless you notch your 305 puley, it will not bolt up. id suggest running the LT1 balancer, either way. Try this:
put the LT1 balancer and the 305 pulley back to back. Bolt the pulley to the balancer via the 2 holes that line up. make sure the crankway lines up. mark the bolt hole thats offset 5 degrees onto the pulley. drill out the pulley. i dont know if the LT1 balancer is drilled all the way though though. If it is, that, IMO, would be the easiest way to get your accessories to work. I dont know if thats even a legitimate idea, lol.
And yes, the LT1 balancer is 2 pieces. The balancer and the hub (the the woodruff key for that hub). unless someone has tried otherwise, i wonder if you could simply remove the LT1 woodruff key, hub, and balancer, and place the 305 balancer on, using the 305 woodruff key? probably wont be the best of balance......
Old Mar 2, 2004 | 10:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
*oops*
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
Linson
Aug 31, 2015 04:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
