92 gauge guide
92 gauge guide
Hi everyone this will be my first post here. I was wondering if someone could point me in the right direction if a thread already exists but I’m looking for a guide in how to get the sock gauges in a 92 to work with an ls. Fuel should be fine because I am going the c5 way. Speedo and tack I believe work through the ecu which will be a fourth gen with a no automotive harness. And coolant plus oil I have heard you have to use adapters for small block style sensors that will connect to the c100. If anyone can tell me if this is right and what I need as far as the adapters to make it all work it would be appreciated.
89RustangRemover
Nov 11, 2001 11:11 PM
