91 camaro rs 6.0/4l60e swap
Car drives great with exception I can not get the trans to go into lock up . On hptuners it’s calling for apply stage and then locked but nothing is happening . I can ground the pin 42 wire and tcc solenoid locks up no problem . Any ideas ?? Thanks
Re: 91 camaro rs 6.0/4l60e swap
The Valve-Body may be using a Pressure Switch or Temperature Switch that is now inoperable.
Drop the Oil-Pan and see what is in there...
You can test for an inoperable Switch, by bypassing it with a Jumper-Wire.
Sorry, I should have asked before...
Is this for a THM700-R4 or a 4L60E?
