5.3 LM7 Cam Advice
Old Mar 17, 2023 | 11:21 AM
87 Fbird's Avatar
Car: 1987 Pontiac Firebird se
Engine: V6
Axle/Gears: 2.57
5.3 LM7 Cam Advice
Building a 1999 LM7 truck motor for my 1987 Fire-bird LS swap. 4L60e, 373 gear, 3000-3600 stall (not yet purchased). Stock heads and flat top pistons oversize (50MM). Building this vehicle for only street use and I am looking for a street/performance cam mainly for mid range with occasional high end. Looking for a solid street cam.
My thoughts are;
Summit 8720 stage 2 high lift truck cam
Summit Ghost Cam
Summit 8707 Stage 2 automotive cam
any thoughts would be very grateful, members and Summit techs..
Old Mar 17, 2023 | 11:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 5.3 LM7 Cam Advice
Welcome aboard. I would call one of the main players in LS cams (Cam Motion, Brian Tooley, etc) and have them talk you through their cams. You'll get what you want, based on your goals, without going too big on the cam. Something under 220 duration and .580 lift is likely where you'll land. I'd spend some time watching cam swap vides on YouTube. Texas Speed and Richard Holdener have countless videos walking through dyno tests of various cams.
Old Mar 17, 2023 | 11:40 AM
87 Fbird's Avatar
Engine: V6
Axle/Gears: 2.57
Thanks I will look into that. I was looking at the Summit 8720 Cam because of Richard's dyno video. Also, Summit 8707 cam might be a little big for my intended purpose from what I am reading.
Thanks..
Old Mar 17, 2023 | 11:49 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thanks..
That certainly isn't a monster cam, but it will act bigger in a 5.3. A small cam, even a step up from stock goes a long way in these cars. Also, if you go too big, you'll have the added expense of buying a matching torque converter. The specs on that summit cam are almost identical to the comp cam I am running in my 6.2. May be a bit too steep based on your goals.
193heads
Carburetors
Jun 7, 2015 08:42 PM
bg383
Aftermarket Product Review
Aug 8, 2009 06:39 PM
slick
Jun 3, 2005 06:26 AM
GofasterFirebird
Nov 1, 2003 12:49 AM
