Will this Clear stock Hood?
Old Oct 12, 2023 | 11:26 AM
OddJack's Avatar
https://www.summitracing.com/parts/mll-bp38318ctc1d
1989 RS Camaro
Old Oct 12, 2023 | 12:08 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Will this Clear stock Hood?
Not likely.
Old Oct 12, 2023 | 12:35 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I'd say no. But that's what cowl induction hoods are for.
Old Oct 12, 2023 | 01:23 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I have a trans am and it probably wouldn't fit, or it would be really close. Camaros have a little more room. You're totally on the line, you may need a different air filter. But the engine will fit nicely and bring joy for years to come! A drop base filter may be all you need.
Old Oct 12, 2023 | 03:23 PM
skinny z's Avatar
I agree that it'll be close.
​​​​​​My 86 IROC with the stock hood had the slightest of contact with a dual plane intake and dropped base air filter case. The RPM Air Gap is taller than what looks to be a traditional Performer intake so you may gain a few fractions there.
​​​​​​Speaking of dropped bases, they're not all created equally. There's a version from GM that's extreme. I can probably dig up a part number.
Old Oct 12, 2023 | 07:40 PM
OddJack's Avatar
Thanks everyone
Anyone can tell what carb is on that engine?
Old Oct 12, 2023 | 07:58 PM
skinny z's Avatar
Holley 750 cfm Carburetor - Manual Choke
https://blueprintengines.com/product...or-bp38318ctc1
Old Oct 12, 2023 | 08:09 PM
skinny z's Avatar
Or your fully dressed version (which has a less detailed description of the parts involved).
https://blueprintengines.com/product...pr_seq=uniform
Old Oct 13, 2023 | 10:07 AM
OddJack's Avatar
Thank you, yes I am going with fully dressed version.
And this radiator, have seen some good reviews here: Dewitts 1.25 tube
Any other parts I need to order to go with this swap?
Old Oct 13, 2023 | 10:30 AM
skinny z's Avatar
A couple things come to mind although I know there are details that others might chime in about.
The rad: inlet and outlet sizes? I ask because the Griffin rad I have has upsized fittings. That is 1-1/2" top and 1-3/4" bottom (rather than the factory 1-1/4" and 1-1/2") so that necessitated a search for hoses that would work
The heads are indicated as having a 1/2" raised exhaust port. You'll want to be sure your headers will accomodate that.
No mention of whether the flexplate or flywheel is included. The (weighted) harmonic damper is included but nothing is said of the backend. It's also a weighted unit so you'll have to investigate that.
You'll need a compatible starter.
There are a number of other items too but it depends on what you're starting with. Alternator, power steering, pulleys and belts, fuel pump and all of the associated bracketry.
Old Oct 15, 2023 | 08:53 PM
OddJack's Avatar
Thanks,
What headers would be best to go with it?
Old Oct 15, 2023 | 10:03 PM
Car: 1983 Z28
Thanks,
Lookup how many brands of headers there are and that’s how many different answers you’ll get.
You can still buy shorties from several brands that are 3rd gen specific, but if you want longtubes you’ll have to buy a set for a 2nd gen and make them work.
Old Oct 16, 2023 | 06:21 AM
Car: 82 TA
You may be able to get some headers from dyno don. They're awesome.
Old Oct 16, 2023 | 06:27 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
SBC same as any other. Performer intake and drop base air cleaner and you will be good.
Old Oct 16, 2023 | 09:23 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
...And this radiator, have seen some good reviews here: Dewitts 1.25 tube...
That DeWitts unit is a solid quality radiator. I bought & installed one earlier this year. The inlet/outlet sizes are the stock sizes so you won't have any issues with hose fitment. One thing you need to be aware of though is fan fitment. With the 1 1/4 tubes, the thickness of the radiator is noticeably larger than the stock radiator. With a much thicker radiator you start running into issues fitting the fans in there without hitting the steering box or pulleys. It can be done with some massaging, but it wasn't fun.
Old Oct 16, 2023 | 09:12 PM
skinny z's Avatar
There are still a few long tube headers available for these cars.
https://www.summitracing.com/search/...yle%3Astandard
I've got the Hedman Street Headers 68460.
The issue with the Blueprint engine is that the exhaust ports are raised 1/2" over the OEM. This may cause some interference with the chassis.
Keep in mind too, that since the demise of the Hooker/Blackheart headers, there's no longer a fully bolt-in header to tailpipe setup. It'll be on the builder to make a y-pipe to adapt the headers to whatever catback exhaust is in there.
Old Oct 17, 2023 | 06:54 AM
Car: 1983 Z28
something must have changed, there was a time when all the sellers had taken these down due to new regulations. I think there was a thread on here about it. Glad to see they’re back!
Old Oct 17, 2023 | 10:24 AM
skinny z's Avatar
I know that the Hooker/Blackheart versions were pulled by Holley. Something to do with the EPA saying that Holley was encouraging car modifications that excluded catalytic converters. True or otherwise, the Blackheart headers were about the top of the line especially considering the packaging available for the rest of the exhaust. And the tech support supplied by the engineer who helped with development was also top of the pile.
As for the OP and the raised exhaust ports, it may well be that I have a similar port architecture but I can't say for certain without being able to compare directly. I know that the Hedmans I posted installed easily, fit perfectly and offer plenty of clearance for the spark plugs and tools needed.
Superjustin13
Exterior Parts Wanted
Jan 29, 2010 02:59 PM
