153/168 tooth flywheel?..
Old Aug 29, 2024 | 02:50 PM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
Guys I need some advice on a flywheel application please. Ive built a 383 stroker using a 1989 5.7 block with a scat 383 kit. The crank and block are a one piece seal. Im going to go with a t56 transmission and understand that they use a 153 tooth flywheel! I believe that the 1989 5.7 block used a 168 tooth flywheel. If I go with the t56 transmission will my starter turn the flywheel???? Thanks
Old Aug 29, 2024 | 03:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 153/168 tooth flywheel?..
Iirc you need a 153, look at spec clutches for externaly balanced one piece rear main. Or centerforce and McLeod has them too. I’d get it sent to your machine shop for balancing with the rotating assembly.
Old Aug 29, 2024 | 03:30 PM
Engine: Lb9
Transmission: M20
McLeod Steel Flywheels 460260
Old Aug 29, 2024 | 03:55 PM
Blocks don't use flywheels.
Transmissions do. More specifically, bell housings.
Both diameters are available that will fit your motor. Once you determine how it's balanced, there's plenty to pick from, of either size.
Old Aug 29, 2024 | 04:46 PM
Axle/Gears: 370
so what youre telling me is the starter bolts to the transmission and not to the engine block????
Old Aug 29, 2024 | 07:03 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
No Lisa. The starter bolts to the engine. However the starter is designed for either a 153 OR a 163 tooth flywheel. Not interchange able. Clutch flywheel size is usually determined by bell housing size. These cars used the 153 flywheel because of the small tunnel. Now you did state your using a Scat crank . Is it a "forged crank" or cast? If its cast then it is external balance which means external weighted flywheel and harmonic balancer. As stated you really should have it balanced by a reputable balancer. They will tell you what flywheel you should use because it needs to be balanced along with the rest of the lower end.
Old Aug 29, 2024 | 08:08 PM
No.
You pick the starter to match the flywheel size you need.
You pick the flywheel based on the transmission, bell housing, etc.
The block does not care. At least, blocks after about 78 or so, don't; before that (the introduction of the 12.8" wheel) they only had the right bolt pattern to fit the starter for the 14" wheel. To put modern transmissions on older blocks often requires drilling a bolt hole for the later model starter. With your 89 block that's not an issue, it has the bolt pattern you need.
Old Aug 29, 2024 | 10:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A 153 tooth flywheel and starter allow a little exhaust clearance.
An LT1 T56 153t flywheel uses an 11" clutch.
A third gen 153t V8 flywheel can use up to a 10.75" clutch. Many are 10.5".
Both the above have bellhousings which need a smaller starter. A third gen V8 T5 starter fits. A 4th gen LT1 starter fits. A third gen 5.7 starter does not. Any starter for a 168 tooth flywheel does not.
So if you listen to the old fellas who tell you to go with the 168, they won't be able to outline one advantage to it.
As I said in your earlier thread, if your 383 accepts a stock balance flywheel, that keeps options open.
Old Aug 29, 2024 | 11:50 PM
To a point... before you buy ANYTHING, you HAVE TO KNOW what your motor was balanced to.
It's easy enough to "unbalance" a stock flywheel, if needed. The stock 12.8" wheel for 86-up (1-pc rear main seal) motors isn't neutral balanced anyway. Butt you HAVE TO KNOW what your motor was balanced to before you bolt everything up. Either a 14" or 12.8" wheel can be made to work with a "stock" 305/350 balanced engine, or can be modified to work with one that ISN'T internally balanced like the 305/350 were, as many 383 rotating assemblies are NOT, or whatever. Regardless, you HAVE TO KNOW what your motor was balanced to. Only way to get that info is to talk to the people that built it.
Nearly all T-56 flywheels (the 93-97 ones are not the same as for other transmissions, apart from outer dia) are 12.8".
Old Aug 30, 2024 | 08:39 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Also a good thing to know is when getting a starter that 153 tooth ring gear will need a starter with 11 teeth on the bendix drive gear. 168 tooth ring gear is nine teeth. The parts stores have given me the wrong one in the past.
RocBoy
Aug 25, 2020 09:01 PM
remltr
Apr 8, 2007 12:09 PM
REALPOWER
Dec 20, 2005 02:18 PM
