I chipped a flywheel tooth, wonderful. Need help.
Old Dec 18, 2005 | 12:20 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Well I went out to crank the Camaro up today and chipped a flywheel tooth. Wonderful, thats just what I wanted to replace. Anyway, the motor is a 1 piece rear seal internally balanced 383 stroker. Nobody seems to make 1 piece, 168 tooth neutral balance flywheels. They are all externally balanced. Can I take the weight off and use it?
After I replace this, I am going to put the ignition on a switch so this doesnt happen again.
Thanks!
Old Dec 18, 2005 | 12:25 PM
5ltrbtr's Avatar
Car: 91' Z28 T-TOP
The easiest thing I can think of is to get a starter to match whatever flywheel you can find. I know this time of year money is so easy to come by
Old Dec 18, 2005 | 12:35 PM
REALPOWER's Avatar
Transmission: Th350
Do you know if I can just take the weight off?
Old Dec 18, 2005 | 01:07 PM
REALPOWER's Avatar
Transmission: Th350
DOH< I mean FLEXPLATE not FlYWHEEL sorry
Old Dec 18, 2005 | 01:12 PM
REALPOWER's Avatar
Transmission: Th350
Like this but without the weight...
http://cgi.ebay.com/ebaymotors/SFI-3...spagenameZWD1V
I have a dual starter bolt pattern, so 153 or 168 would work.
Apparently I own the only internally balanced 1 piece rear seal 383 on the planet.
Old Dec 20, 2005 | 02:18 PM
Zero's Avatar
Car: 1988 Camaro
Engine: 5.7 liter motor
Transmission: Four speed automatic
Perhaps you can replace the fly wheel with an aluminum one. It add a bit of engine life and horse power and it'll rev faster.
gta892000
Aug 11, 2019 11:16 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
italiano67
Sep 22, 2015 08:42 AM
dimented24x7
Sep 17, 2015 06:58 AM
