85 Camaro best option for engine swap to use lt1 t56
Car: Camaro
Engine: 305😞
Okay so I have a stock 85 Camaro z28 hard top 5 speed. That I have had for years I won’t to get rid of the 305. I came across a complete 94 trans am t56 that had a broken flywheel I got the whole car for $500.
I won’t to use the t56. but not sure what engine to use would it be easier to convert the lt1 to carb and hei distributor or to get a l31 vortec 350.
iam open to other thoughts and opinions I won’t to keep it carbed as that’s the way it came from the factory
Engine: 4++,350 & 305 CIs
Re: 85 Camaro best option for engine swap to use lt1 t56
Go big or go home!!
Chevrolet Performance 19432060: ZZ632 | ZZ632/1000 Deluxe Big Block Crate Motor | Tall Deck | 632 ci | 1004 HP | 876 ft.-lbs. TQ | 4.600 Bore | 4.750 Stroke | Forged 4340 Steel Crank | Forged Steel H-Beam Rods | Forged 2618 Aluminum Pistons | RS-X Heads - JEGS
Just kidding. Any SBC engine of choice will fit. What are you wanting to do with the car? I like bigger cube engines, just more fun to drive.
Car: Camaro
Engine: 305😞
I just want a fun driver around 400hp and the t56. I have also have a couple 5.3s a lq4 6.0 and a 72 350 4 bolt main sitting in the shop I could use. I just don’t know the easiest most cost effective way.
one more question I have is I would like to have a one piece rear main seal but wondering what dampener and flywheel I would need or would I need to have it all balanced.
Easiest cheeeeeeeeepest and most satisfactory way to get 400 HP in a "fun driver" is going to be the LQ4, by far. What you'd need to do for a flywheel will depend on which LQ4 it actually is, of the 2 main variants.
Car: 84 Bird-28k original miles
Transmission: M29 T56
Axle/Gears: Moser 9" 3.89 Detroit Locker
I’m finishing up a LT1/T56 swap as we speak into an 84 Firebird. If it’s a 2 piece rear seal, you’ll need a new flywheel to be able to use the T56. . It would be an easier swap to leave the LT1 carbureted, but you’ll need to get the carb LT1 intake, a good carb, and non computer controlled hei. I wired my car for fuel injection.
Jake88maro
Apr 17, 2012 11:15 PM
