1984 z28 engine swap
Old Dec 11, 2024 | 09:45 PM
3rdgenCan's Avatar
I知 engine swapping my Camaro, it originally had a 305 in it. I知 buying a 383 blue print engine from summit racing, I知 wondering since the new engine makes more than double the hp (440)as the stock engine will I need to upgrade my transmission or rear end?
Old Dec 12, 2024 | 07:27 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 1984 z28 engine swap
Need? No. Are you going to use 350 hp of that 440 hp? You are? Then yes, yes you will. The axles and transmissions and chassis and brakes and well everything, are fairly weak in our cars. Modifying a thirdgen for more power equals a lifelong project usually. But that's part of the fun. Good luck!
Old Dec 12, 2024 | 07:43 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
It all depends on how hard you are on it as to when the trans & rear end will go out. Might be more convenient for you to rebuild the trans when you do the swap rather than wait until it goes out.
Old Jan 15, 2025 | 03:06 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
The OEM transmission and rear end are not rated for that much power. They will live for a while if you are nice to them, but you should be planning for upgrades.
85z28_eli
Jun 29, 2024 08:15 PM
juanmhiii
Aug 19, 2013 07:29 AM
BOLENBEVEL86
Jun 10, 2010 08:22 PM
aaf815
Theoretical and Street Racing
Nov 21, 2004 12:48 PM
Daishi
Jan 24, 2004 03:02 AM
