I know to replace knock sensor, but what about knock module?
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
The knock module is on lt1 and lt4 engines. I could be wrong but I don't believe they were used on tpi motors. As far as being simple. The lt1/4 is about a 2 minute job, with a torx bit and a small flat blade screwdriver.
Kory
Kory
Transmission: 4L80E/4L80E
Module not used on TPI?
Of course TPI has a knock sensor module. In the distributor.
They go together. Change the type of sensor, then change the type of module.
