I may have to do the Corvette EGR thing!!! using Non heat riser heads
Old Feb 25, 2002 | 06:08 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I'm installing a 383 in my 88 and the AFR heads that I was going to use are the new casting that doesn't support the "drill a hole" for EGR method.
I'm still checking to see if we can't replace them for part# 1038.
If we can't I'll have to do the Corvette style EGR thing. Does any body have picts of how they routed the pipe and if they moved the coil and whatever was needed to convert to non heat riser heads.
Old Feb 25, 2002 | 08:38 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Never mind I was able to swap for the correct heads.
CRFred
Feb 7, 2016 11:39 PM
Bob88GTA
Aug 18, 2015 03:31 PM
milk
Aug 10, 2015 06:26 PM
drathaar907
Aug 6, 2015 04:20 PM
