Bellhousing bolt removal?
Old Mar 2, 2002 | 11:29 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'm trying to do a motor swap but I can't seem to get a bite on the four bolts on the sides of the tranny. I got the tops ones just fine, well not just fine but I got them. Any suggestions for tools or approach?
Old Mar 3, 2002 | 12:49 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Really? theyre the easy ones. Just use a 3/8 drive, a long extension, and a swivel adaptor at the end with the socket. That should do the trick. Also, remember to remove the starter, if you already didnt.
Old Mar 3, 2002 | 04:00 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
It is usually the other way around,with the top two being the hardest for most people.Just do what 88 WS6 TransAm GTA suggested and you should be good to go.
Old Mar 3, 2002 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For me, the two on the driver's side were really tight. I used an offset, open end, turning about 1/2 flat at a time, took forever, couldn't get one of them out completely (had to pull the engine forward slightly while loosening), etc., etc., etc.
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
theurge
Aug 21, 2015 12:46 PM
383backinblack
Aug 15, 2015 06:36 PM
3rdgenparts
Aug 8, 2015 07:09 PM
