How do you remove motor mounts clamshell?
Car: 1990 Formula 350
Engine: L98 350
Are the nuts in the crossmember welded or do you have to get a special tool. Or do you have to remove the control arm?
Thanks, Gary
Thanks, Gary
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
The frame mounts are a pain to get to but they can be removed without dropping the arms.Use a swivel socket and extension on the bottom nuts.Have the car up on jackstands.Spray liquid wrench on the nuts to free up.Have someone hold the wrench on the top bolt while you locate the bottom nut.Pick your best way in.
To install ,find something to hold that nut on your socket,I used a dab of silicone.Reach up thru the same way you removed.I lost a couple nuts I had to fish out with a magnet but with patience its easier than dropping the arms I think.I have a Helms factory manual and a Haynes but neither one told me how to get those off.They just said remove bolts.Yea right!
Engine: L98 350
Thanks guys. Now that I know that I am thinking of just taking the welder and tacking the nuts onto the crossmember like they should have been done in the first place. They should be easy enough to remove then.
NBrehm
Aug 5, 2015 07:57 PM
