do i need to change the thermostat for a motor swap?
Old Mar 4, 2002 | 10:33 PM
fattie92's Avatar
i curently have a 84 TA with a 305.. im putting in a 350.. will this mean i need to change the thermostat too?? which one should i get?
Old Mar 5, 2002 | 08:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't "need" to change the thermostat. It's a good idea to do it while the radiator is drained, though. They have been known to fail.
The stock thermostat is 195 degrees. Cooler typically means you'll make slightly more power. I've used a 160 in the summer when spending time at the track (cools down more and quicker), but it probably isn't necessary. I use 180 in the winter just so the heater works better.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
perZ
Aug 15, 2015 01:17 PM
