View Poll Results: Sealing fuel fittings
thread sealer
25.00%
teflon tape
75.00%
Voters: 4. You may not vote on this poll
Sealing Fuel Fittings
Old Mar 9, 2002 | 01:42 PM
Dragula's Avatar
Getting ready to hook up my new fuel system and wanted y'alls opinions as to the best way to seal the fittings...thread sealer or top part of threads with teflon tape.....
Old Mar 9, 2002 | 02:27 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Fuel system should have dry seals. If you can't get a good dry seal then you're using the wrong fittings. Try -AN fittings or brake line compression fittings.
Whatever you decide, DO NOT!!!!!! use teflon or thread sealant or you can plug your carb. This is common knowledge with experienced people. I don't care what others may tell you. Save yourself from a terrible headache.
Old Mar 10, 2002 | 04:15 PM
Dragula's Avatar
Yeah....thought so. I had heard that before but was told they needed seals. My whole system that I bought has -AN fittings and 3/8 NPT adapters for the pump and regulator. Just figured I would see what "the experts" thought. Thanks for the re-assurance!
Old Mar 10, 2002 | 04:35 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Don't over-tighten the NPT fittings either or they will leak.
Old Mar 10, 2002 | 04:48 PM
Dragula's Avatar
Is there a certain torque range or just snug 'em?
Old Mar 10, 2002 | 05:39 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I always do it by feel. Couldn't give you a number. They don't have to be very tight. It's better to leak a bit and run them down more than to tighten too far and have to get a new one. If you have an electric fuel pump it will be a piece of cake. Just clean up the mess before you get the engine nice and hot.
Old Mar 10, 2002 | 06:54 PM
Dragula's Avatar
Thanks for all the info....this forum rocks!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
R3500
Aug 17, 2015 12:16 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Firebird sweden
Aug 16, 2015 05:02 PM
