motor confusion
Old Mar 14, 2002 | 09:32 PM
senjorb0b's Avatar
motor confusion
i have this so called "350" that i just bought.
i just found the engine codes for it and they tell me that the engine is a 307.
the engine runs, but not right. figured maybe the carb that is on it is too big, its a 750 cfm. the engine block code is 3932373
can anyone verify if what i found is true, or if it really is a 350?
thanks
Old Mar 14, 2002 | 10:01 PM
iroc22's Avatar
The engine should be a 307 alright. 3.875 bore 3.25 stroke. Maybe it doesnt run right because the carb is in need of a rebuild. How does the carb look?
Old Mar 15, 2002 | 12:48 AM
senjorb0b's Avatar
the carb is brand new, just put it on about 2 weeks ago. but im pretty sure that if the engine is a 307 the 750 cfm carb is too much for it to handle.
im also going to check the distributor because the guy I bought it from put it in himself, and probably didnt line it up right.
RazorN8
Jan 7, 2022 11:44 AM
lt500r55
Sep 1, 2021 01:30 PM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
