305 motor w/350 heads
Old Mar 15, 2002 | 12:04 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
i have an 87 TA w/350 block with 305 heads, carbed, is their any specific reason this is or can i throw a set of 350 heads on?
Old Mar 15, 2002 | 12:49 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
The engine is a 350 right? if so leave the 305 heads on the engine. I have put 305 heads on a 350 before and as long as the heads have bigger valves in them then the stock 305 ones your Ok. The reason people put 305 heads on a 350 is because it's a cheap way to bump compression, and compression usually means more horse. So if it runs good and doesn't give you any problems go with it.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
