How Much HP Should I be Looking For?
Old Mar 26, 2002 | 06:52 PM
ThirdGen Stoner's Avatar
OK, here is the engine specs:
350 bored .040 over
Victor Jr. or Performer intake
305 heads angle grinded and oversized vavles
600cfm Edelbrock elec choke carb
Flat Top pistons (not sure of brand though orderd out of a Speedway mag)
Pink rods
Steel Crank
2500-7000 Racing Cam
No smog equipment or computer
Open Element K&N air filter
Old Mar 26, 2002 | 07:10 PM
Mug-'s Avatar
Could you be a bit more specific on the Cam and Heads?
Desktop Dyno gave me - 513hp @ 7000, 436ft lbs @ 5500, But that is just guessing at the Cam and Heads.. So those numbers prolly arn't what you will end up with.
Old Mar 27, 2002 | 09:27 PM
Ok i dont know anything about the cam. But the heads have been shaved about .020's. And the intake valves are 1.94 and im not sure on the exuast. Sorry for the lack of knowlege at this point... BTW im sure those numbers are a bit high (i hope so anyway LOL) i was looking at about 325-400hp. But if thats what it is.....ill take it. hehe
Thanks man.
Old Mar 28, 2002 | 03:20 PM
Bort62's Avatar
Hmm, Flattop Pistons.,,, 58 CC heads.. .020 Off the Head surface...
your going to have a compression ratio around 12:1
I hope you havent actually bought any of this stuff yet...
I give that motor 20 miles bfore the detonation Kills it.
Old Mar 28, 2002 | 08:22 PM
I doubt it, scince that motor has already been in about 10 races. (its a spare race motor-circle track) And if it did not blow then, then I dont think its going too. It was turning about 6,500 rpm too...
Old Mar 28, 2002 | 08:52 PM
1stgenracer's Avatar
I got 452hp at 6500 rpm's, i'm not sure if that is right though considering that i have not been useing dd2000 very long, hope it helps.
Old Mar 29, 2002 | 07:52 PM
Sounds cool man, thats a lot hehe. BTW how much are those desktop dyno programs? Thanks.
Old Apr 1, 2002 | 04:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if its got alot of compression than it will just ping/ detonate like crazy on good ol' pump gas. They run 110 octaine racing fuel in those...
Old Apr 1, 2002 | 04:42 PM
Car: 88 Camaro SC
Engine: SFI'd 350
if you find a large unknown stockpile of leaded gas, than buy it, otherwise, your money is better used elsewhere.
