lowest compression pistons?
Old Mar 29, 2002 | 06:44 AM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hi again,
I am just wondering, what is teh lowest compression piston you have seen?
What is done to a piston to make it lower compression?
I know you can make a cup in it but what more can you do?
Thanks :hail: :hail: :hail:
Old Mar 29, 2002 | 07:15 AM
83 MidniteZ's Avatar
Cylinder compression has a lot of other factors then just the piston. To lower compression, piston companies may dish the piston and put valve reliefs in it, but compression has a lot to do with combustion chamber size of the heads, deck height, gasket thickness, bore and stroke size.
Old Mar 29, 2002 | 07:48 AM
Trux's Avatar
Transmission: t-56
oh
I am still looking for some nice heads, I am leaning to edlebrock victor 23 degree heads with a 71cc chamber and 247cc intake port.
What do you think?
thanks :hail: :hail: :hail:
Old Mar 30, 2002 | 11:11 PM
Guest
Guest
Posts: n/a
Re: oh
What do you think?
I think those heads belong on a race car and not a street car of any sort. Ports are WAY too big to be useful. If you are going to go off the deep end and use full race heads, dont use 23 degree heads, use something else like 14-18, easier to make more power with those.
Old Mar 31, 2002 | 07:30 AM
Trux's Avatar
Transmission: t-56
alrighty
They have some 18 degree heads also.
I am just lookin at them, they do cost alot.
thanks:hail: :hail: :hail:
Old Mar 31, 2002 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well my little bro built a 427 once, with 454 pistons, because he thought they were for a 427 and slapped it together without paying much attention until it was too late, so he finished it anyway... that gave it about .060" too much deck clearance... we figured it had about 7:1. It ran OK though, kind of weaker than it should have been, but at least it never pinged no matter what kind of gas he put in it.
Old Mar 31, 2002 | 03:55 PM
Trux's Avatar
Transmission: t-56
WOW
7:1, that is very low. I'll try to do some reach about larger pistons in a small block.
Thanks:hail: :hail: :hail:
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
