Swapping out a 91 305TPI
Old Mar 31, 2002 | 04:37 AM
89Formula5.0's Avatar
I am wanting to swap out a 91 305TPI for a 92 350TPI. The only real question that i have hear is it will it work? The car is an 89 Formula 350. The previous owner had swapped out the 89 350TPI for a 91 305TPI.
The car still has all the original equipment from the 89 350TPI. The only thing that it has changed is that it is now a 91 305TPI instead of a 89 350TPI .......... My question now is will a 1992 350TPI work on an 89 Formula 350TPI? What will i need changed on? What if I keep my MAF? What changes or mods would be needed to have my car running right?
Thanks in advance!!!!!!!!!!!!!!!!!
:hail:
:hail:
:hail:
Old Mar 31, 2002 | 05:37 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Everything is EXACTLY the same with the exception of the knock sensor, and the injectors. Other than that its a direct bolt in.
BTW: Why the hell would the person who owned your car before you swap a 350 for a 305?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
jbd1969
Aug 17, 2015 07:06 PM
