400 Sbc
Old Apr 4, 2002 | 12:08 AM
mat89RS's Avatar
400 Sbc
I have access to a SBC 400 from a 1974 trans am for 300$ it comes with a TH400 and the guy says it has new gaskets but the engine wasn't fired in 2 years ...
Should I jump on this deal ?
Would the be better then my LT1 ?
What can I do to it to make it over 400 hp >
Thanks guys
Old Apr 4, 2002 | 06:28 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
74 Trans Ams had Pontiac 400s in them here in the states, don't know what the Canadian cars had though. Might want to check it out before you buy it. The pontiac motor won't just bolt in you will have to do some fabrication work.
Old Apr 4, 2002 | 09:53 AM
mat89RS's Avatar
That's the engine , does it tell you more about it ? also I might be able to get a TPI for 80$, if I get a 900 cfm trottle body and larger runners and port the intake, will it work ???
Old Apr 4, 2002 | 03:24 PM
mat89RS's Avatar
OK , just figured out by myself that it was indeed a Pontiac 400...
anything to do with these engine ??? would that be a good S-10 v8 convertion ? how much power ?
gixxer92
May 18, 2017 11:20 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
