harness swap in LG4 to TPI?
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I would like to swap in a TPI motor in both my '81 Elcamino, and my '82 T/A. The stock ecm in both cars have two harnesses. One from the dash, and the other from the engine bay. My question is would I need to swap both, or does the dash harnes work? Am I heading in the right direction with this question?
Guest
Posts: n/a
The TA dash harness will probably work as is. The El Camino you will have to move the wires around on the connector from the dash to the ecm/engine. I'd suggest you get a good wiring diagram, you'll need it.
Both you will have to replace the engine-ecm wiring harness.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Dash harness on the 82 needs to be modified slightly.
You'll need to run Injector power to the engine harness from an ignition source as well as Ignition On ECM power.
The ALDL is wired up differently as well.
Sanjay
Aug 12, 2015 03:41 PM
