pulling motor, have questions
Old Apr 10, 2002 | 09:36 PM
IROC-ZWV's Avatar
ok guys, we are pulling this thing (88 305TPI) out tomorrow...today i got the manifolds loose and all the coverter stuff on them that runs to the cat or engine....all thats off...all the little metal tubes.
..do they have to go back on? can i just plug the holes?..
I dont have a smog test or anything to get a sticker (WV) will this cause my engine lite to stay on or something?
Im taking the injection system off before I pull it....will i run into any problems?
I had the cut the heat shield on the driver's side..how big of a mistake was that?
while this babys out is there anything i can do to the tpi thats not really expensive that might help performance/looks?
thanks in advance
chris
Old Apr 11, 2002 | 02:00 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
just plug 'em... I dont belive pulling the air sytem off will trip any codes.
Old Apr 11, 2002 | 02:09 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Remove the AIR system & plug um up.
It will be easier to work on the FI with the engine out.
You can port the plenum while it's apart.
MustangBeater20
Oct 29, 2022 09:20 PM
Steve78LT
Feb 24, 2016 12:15 AM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
