Big block power steering
Old Apr 12, 2002 | 06:34 PM
8.2L Trans Am's Avatar
Hey, I am new to this board but have been viewing the threads for awhile. I am in the process of putting a big block in my 87 Trans AM and was wondering if my power steering pump brackets from my small block will fit the big block. I really don't think they will. How about the March power steering pump brackets, they are pretty expensive but I think I will need a new pump to use the brackets. I've even looked into an S-10 manual box but have my doubts about it turning the tires with so munch weight on them. Any help would be appreciated. Thanks
Old Apr 12, 2002 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need BBC brackets for everything.
I use a manual box with no problem. A BBC is only about 100 pounds heavier than a SBC. The hard part is trying to turn at low speeds with wide front tires.
Old Apr 12, 2002 | 11:59 PM
CrazyRob75's Avatar
this is my second summer street driving my car with the 454 and S10 box. it really isn't that bad.
Old Apr 13, 2002 | 09:13 AM
That’s cool so what about the March power steering brackets #mch-20150 in the summit catalogue. If I used those brackets I would probably have to buy a new power steering pump right? I have already purchased a March alternator bracket so the power steering bracket would go well with the rest of the engine. As for the manual box I plan on using the stock width tires and am not going to put skinnys up front for a while or maybe never. So I’m not to sure 100 pounds is about the extra weight I expected plus I made sure to buy lightweight parts if possible anything that could be made in aluminum was except for the block.
Old Apr 14, 2002 | 10:09 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've been using the s10 box for a couple of years now with no complaints.
Miles
Old Apr 16, 2002 | 09:08 PM
EvilCartman's Avatar
Car: '82 Z28
What year S-10 box should you use?
Old Apr 16, 2002 | 09:16 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
85-90, some s15's will also work.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
