IROC center caps
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
IROC center caps
After spending about 4-5 hours on each wheel sanding and polishing they have come out pretty well. The main weakness now is the center caps. The emblem sticker is coming away from the retainer making them look a little tatty.
My question(s) are;
1) Can the plastic be sanded and polished for a clean look? If so how?
2) Can you glue the emblem onto the retainer? I have done this but not very well and it is curreently on but wonky.
I would prefer not to fork out £30 or so to get some new ones, but reckon it may well be the only option. Has anyone had similar experience and if so how did you resolve? Any suppliers over here you could recommend?
Thanks,
Felix
My question(s) are;
Thanks,
Felix
Car: 91 camaro rs
Hi Felix
Give North Hants Tyres a ring (Fleet, Hampshire). I got my IROC centre "discs" from there. I assume you mean the little discs that go into the centre of the wheels.
Let me know if you want their phone number and I will look it up.
Post a pic if you can.
Andy.
Andy.
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hi Andy,
Yes I mean the discs, both the metal holders and the IROC graphic that is stuck onto them. Somehow the sticker has lifted from the holder and it is now slightly wonky.... How much did you pay through North Hants?
I'll try and get a pic asap.
Cheers,
Felix
Cheers,
Felix
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
uhh, polishing plastic is funny, it will either gleam like crazy, or it will go dull.
i'd say try a small part of the cap (somewhere hard to see, in case it goes dull) and just poligh the way you do with paint. brasso wadding is a good starting point, then something like Autoglym super resin polish to finish it off.
worth a try.
incidently, this method works superbly on tail lights (use t cut first if they are really bad, and be expecting to have to use about 5 or 6 coats of polish, and work it in well)
worth a try.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
