European Region For all of our Third Gen brothers and sisters across the pond!
Big,big Brakes
Old Feb 13, 2004 | 02:39 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Big,big Brakes
Thought that now ive finally bought a digi camera,I would post some pics of the big calipers that i bought some time ago.Unfortunately they wont go behind even my 18" rims but maybe next year i'll put that right
PM
Old Feb 13, 2004 | 02:40 PM
powermite's Avatar
Car: Transam
and
Old Feb 13, 2004 | 02:41 PM
87Formula4bbl's Avatar
Car: '87 Formula
: Drool :
Old Feb 14, 2004 | 02:02 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi Powermite,
How much did those bad boys cost you?When you say they don't fit do you mean they're clashing with the wheel diameter or the wheel depth?I'm trying to get as much info as I can before I buy some wheels to go over my Brembo monobloc 4-pot calipers.
Old Feb 14, 2004 | 02:25 PM
powermite's Avatar
Car: Transam
Eric,
Well as you know ive got 18" but these are made in an unusual way.The centres are only 16" and then the rim in manufactured to make it up to 18"
What we both need are 18"rims that are flat on the front a bit like front wheel drive cars then that will give enough room for the caliper.That caliper of mine is 6"wide so needs a lot of clearance.
They are 6 pot and are similar to those used on touring cars and endurance cars like at Lemans.
Cant tell you what i paid but if you were to buy from Baer i think they are about $2000 each.
You may see what i mean about the wheel in this pic.
Bare in mind the disc is 13"dia and you can see that the centre of the rim is not much more
PM
Old Feb 15, 2004 | 08:00 AM
Car: '92 RS Camaro
Transmission: TH400
Hi Powermite,
I've done a few searches and posted a few topics about fitting big brakes inside wheels.Haven't had much joy though.One option I thought of was to get some wheels(I'll almost certainly get Boyd Coddingtons from a shop in Arizona) in a 4th gen pattern.I'll then need some Skulte 2" adaptors.This extra 2" should improve the clearance enough for the calipers.What are your thoughts?
Old Feb 22, 2004 | 05:30 PM
irocfan's Avatar
nice set of brakes... well out of my budget - anyone tried fitting 'vette units (or indeed any other make of calipers?)
Old Feb 23, 2004 | 12:59 AM
powermite's Avatar
Car: Transam
Iroc,
The brakes fitted on my car now are vette ZR1 calipers and discs.
My original 16"wheels wouldnt quite fit over them,although if i had ground a bit of the caliper casting away they probably would have,but i think the 16"Camaro wheels offer a bit more clearence so should fit ok,
The stub axles need to be modified and drill though,its not just a case of bolting them straight on
PM
Old Feb 23, 2004 | 01:26 AM
irocfan's Avatar
think i need to talk to you at one of the shows!!
Old Feb 23, 2004 | 01:33 AM
Kandied91z's Avatar
nice.............
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
