European Region For all of our Third Gen brothers and sisters across the pond!
Exhaust Pipe Problem.
Old Jun 21, 2013 | 01:28 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I trying to tidy up the exhaust on my 82 Firebird. It has the 2.8L V6 engine. I want to get the section from the manifolds on each side of the engine then goes under the sump and then turns where the cat used to be. I have gone to three exhaust places here in Ireland and none of them can bend a pipe. What has happened to this country. I was wondering is there anywhere in the UK I can buy the sections and weld them together myself. The sections I need there are quite a few bends on them.
Thanks.
Old Jun 21, 2013 | 01:44 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Exhaust Pipe Problem.
So you need a new Y pipe?
Old Jun 21, 2013 | 02:25 PM
gholian's Avatar
Engine: 2.8 V6
Yes, I suppose I do. See you are in the US. You probably have no bother in getting these. I on the other hand can't.
Old Jun 21, 2013 | 02:30 PM
midias's Avatar
Found this but it says 85 and up
http://www.summitracing.com/parts/wl...2/applications
Maybe someone in the exhaust section can tell you what needs to be done to make it fit. I would post there.
Old Jun 21, 2013 | 03:55 PM
gholian's Avatar
Engine: 2.8 V6
Thanks, that looks very close. Shouldn't be much modification to be done but will post in exhaust section.
Old Nov 5, 2016 | 12:46 PM
senior bear's Avatar
HI i recently purchased a kit from summit dule pipe kit from front to back $198 plus shiping its for a 5.0 and bolts to the headers .with a bit of cuting and welding im sure you could adapt it to fit .fited mine on a 5.0 firebird scraped the cat put a crossover in place a pair of cherry boms on the end .freed up a lot of power sounds good and did not cost a fortune
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
