Help FAST...Cat Back INSTALl!!!
Old Apr 19, 2002 | 05:35 PM
TransAm87's Avatar
I just got a used american thunde series cat back for my 87 Trans am. It was used so when it was taken off it was cut where hte pipe goes over the axel and then welded back toghether. What is the best way to install this pipe? How is the easiest was to get the complete thing over the rear axel?
POST ASAP
AJ
Old Apr 19, 2002 | 07:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You might need to raise the car up so the rear end will drop down some.
Old Apr 20, 2002 | 01:52 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
If its one piece you really need to get the car in the air like Marc said. My friend greg got the Dynomax and their i pipe is one piece, he had to get it up on a lift to put it in. Luckily he knew the guy at the local Marathon so they let him borrow it. My force II system came with 3 separate pipes for the i-pipe, made installiation a breeze.
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
