Is there anywhere to buy weld on A.I.R fingers??
Old Apr 17, 2002 | 12:57 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I think I remember seeing that you could buy A.I.R fingers and fittings that you could weld onto headers, is this right? I want to get Long Tube headers and since none come with A.I.R equipment I want to look into buying the fingers and fittings and welding them on. Thanks.
Old Apr 17, 2002 | 02:01 PM
sIcK pUpPy's Avatar
I think that SLP sells 'em.
Old Apr 17, 2002 | 02:18 PM
sIcK pUpPy's Avatar
Yup, $95 bucaroos!
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Lates,
JD
Old Apr 17, 2002 | 03:48 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Cool, thanks a lot. Kinda sucks that they're that much but I my only real choice is SLP headers or Long Tubes, and Long Tubes are cheaper and give more power. If there's anywhere else that sells them cheaper please post. Thanks again.
Old Apr 17, 2002 | 05:00 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I think Hedman has the weld on air tubes for much less but not sure how much.
If I can make a suggestion, why not just weld a single tube on one of the primaries on both headers with the AIR check valve fittings?
If you look at the LT1 smog legal headers you'll see what I mean. Also the MAC headers for the third gens are setup like this.
Check it out....
http://www.macperformance.com/macsto...o/cmrohdr.html
Scroll down to the bottom.
IMO it looks A LOT cleaner than having 4 tubes sticking out of the primaries. Just my 2 cents.
Old Apr 18, 2002 | 03:39 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Check it out....
Cool, that's an interesting idea, and it does look a lot cleaner. Thanks.
Old Apr 19, 2002 | 03:32 AM
Jza's Avatar
Jza
Not to mention you can bend that up yourself for next to nothing. It might not even have to be at the collectors. I think Chevy pickups have only one or two AIR tubes mounted on the center ports by the head, right? I'll have to look at my dad's sometime when I go over there.
Old Apr 20, 2002 | 03:36 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Instead of blowing $100 on that slp stuff, just use the stock AIR tubes from your manifolds? They come right off and i'm sure it wouldn't be difficult to bend and cut the tubing to your desire.......
BumpaD82
Feb 26, 2016 02:57 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
dbrochard
Oct 3, 2015 12:43 PM
Lanz06
Sep 14, 2015 07:16 PM
Jlanz55
Sep 8, 2015 11:28 PM
