Exaust Manifolds
Old Apr 20, 2002 | 11:43 AM
Robert Bertrand's Avatar
Car: 1986 Ta/Firebird
Engine: 305 0.30 over(310ci)'dyno'd @10:6.1 cr. , 462 heads,Ported. edelbrock eps manifold,2701 cam,1406 carb.Headman Headers.
Transmission: 5 Speed
Exaust Manifolds
Need Help on some Stock exaust manifolds.I have a 1986 TA carburated model 305 and need to know if the Spark Plugs go over or under.Cant seem to find the correct ones.all the ones i looked at the Last bolt pattern on the passenger side is to long for the head..
Need help Badly,getting a Big Headache
Old Apr 20, 2002 | 07:05 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The plugs go under the manifold. You've been looking at the correct manifolds. The passenger side manifold uses a 3d bolt hole further back in the head. Not all chevy heads have that 3d hole. I had to order a different set of heads for my 87 because the heads i had(not stock) were missing that hole. Headers will fit without the extra hole.
Old Mar 22, 2005 | 04:19 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
https://www.thirdgen.org/techbb2/sho...73#post2245773
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
