Exhaust leaks.
Old Apr 23, 2002 | 09:00 PM
VampireHunterC's Avatar
Exhaust leaks.
I have an exhaust question. As I have said before, I have true duals with glasspacks. Unfortunatly, it is a "shadetree mechanic" exhaust system. Everything is bolted or clamped togeather, and nothing is welded. I do not have the money to have a system "professionally" welded. I know about the leaks from the headers and reducers, and I tighten them up whenever they get loose. However, the leak is still there. Could I have some leakage from where the pipes and mufflers are clamped togeather? Could I use "exhaust tape" (saw it at autozone) to block off the suspected leaks from the clamped areas? Or, am I just smelling exhaust because there is no cat and I run with the windows down? Also, my weatherstripping leaves something to be desired. Could that have anything to do with it? My system runs like this: headers with gaskets-reducers with gaskets-pipes clamped on to reducers (with size adaptors thanks to heddman sending me the wrong size pipe)-glasspacks clamped on to pipes UNDER the rear bumper-exhaust tips clamped onto mufflers. Also, it is flex-pipe .
Also, does the placement of the mufflers affect sound/backpressure/anything?
Old Apr 23, 2002 | 09:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A leak will produce a ticking sound, if you don't hear anything, I would say you're smelling the fumes.
Old Apr 24, 2002 | 12:00 PM
Haven't heard any ticking, so I guess it is the fumes. So, how do I keep the fumes out of the car? Will it always be a problem with the windows down? Would attaching a cat to each pipe help?
Old Apr 24, 2002 | 10:05 PM
TBI305Camaro's Avatar
happens to me to when im sitting still with the windows down (took out the AC so...) and every connection on mine is welded
Old Apr 25, 2002 | 11:53 AM
Chronic problem with thirdgens, then? Oh, well. Guess I'll have to get the a/c fixed.
Old Apr 29, 2002 | 03:12 PM
So, is this a chronic problem, or can it be fixed? Will cats at least get rid of the smell?
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
86IROC112
Nov 27, 2015 09:54 AM
Stryker412
Sep 20, 2015 06:59 PM
david068513
Sep 18, 2015 10:36 AM
