POR-20 coating on headers
Old Apr 24, 2002 | 01:31 PM
dan84transam's Avatar
Hi, I recently installed a set of headers on my 84 Trans AM. These headers have no coating.
I’m thinking of using POR-20 Brilliant Aluminum coating. It says its for headers and can handle up to 1400 degrees.
Has anyone used this kind of coating on headers ? or anything like it.
It cost $16 for half a pint or $24 for a pint. Any idea how much it'll take to coat a set of shorty headers ?
Any ideas, comments, suggestions appreciated
Thanks,
Dan
Old Apr 24, 2002 | 03:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've used a spray ceramic hi-temp coating 1200* before and it lasted a month or so and started to flake off. I'm planning on buying some 1500* kind I saw in summit or jegs, can't remember, that should do the trick.
Old Apr 24, 2002 | 05:54 PM
Mark, I think I found what u were talking about..
http://www.jegs.com/cgi-bin/ncommerc...br=76&lastcat=
up to 1500 degrees.. comes in a spray can. The POR-20 stuff comes in tin can and can be bushed on or even sprayed on. By reading about their products, it sounds good. And their reputation for POR-15 is good.
http://www.por15.com/hightempcoating...BrightAluminum
I’m thinking I'll sandblast my headers real quick and put this stuff on. I just want a cheap protective coating for my headers so it wont rust up. Hopefully it'll even help reduce the engine compartment temps.
Dan
Old Apr 24, 2002 | 06:58 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Mark check out this place they do ceramic coating for $100 for shorty headers and they are only down in VA.
www.thermaltechcoatings.com
Dan if you go to thermaltechcoatings.com they will found an applicator close to you
Old Apr 24, 2002 | 07:03 PM
THETANK's Avatar
Car: 91 rs
sorry Dan i meant
www.techlinecoatings.com
Old Apr 25, 2002 | 12:45 PM
DozaChris89TA's Avatar
Hey Dan I used the por-20 that you are talking abouit on my headers and its been 4 months and there still is no rust. Sandblasting is deffinatly recommended along with 2 coats of the por-20. If you brush it, which I recomened, you will only need that half-pint and you will still have plenty left over in the can. The stuff goes forever. All I used were a couple of foam brushes, 1 inch and 2, that you pick up from your local paint store. Good Luck with whatever you choose.
Old Apr 25, 2002 | 12:55 PM
Car: 99 Formula
Axle/Gears: 342
Thanks, but with my headers already on the car, it will probably be a lot more.
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
