gutting your cat and the sound you get...
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'll just say, don't. Get a high flow converter or a pipe in place of it.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
hollow sounds like crap. with a pipe on there with the same setup the sound will be better and louder
Car: RS
Transmission: 4L60
I didn't weld it, and now I wish I would have cause it is starting to leak, of cousre I didn't clamp it either because it was a tight fit, maybe I'll get the jb weld out
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Replace the cat with a section of pipe and weld it on. That's how mine is and it sounds pretty good for being all stock.
im at the same point u are now.. the pipe is starting to push itself out of the cat, and it is leaking where my pipe is going into the cat.. I had inspection last week so i JB welded the whole thing for the second time.. first time i used quick JB quick weld and it didn't hold.. Looks kinda crappy, im going to eventualy get a real cat..
[Sold] Dual cat y pipe
Eric-86sc
Sep 22, 2015 08:25 PM
