SLP Header Q's
Old May 6, 2002 | 08:28 AM
spodeboy's Avatar
Car: 1986 IROC
Engine: 400 SBC bored .060
Transmission: Tremec TKO
SLP Header Q's
I've got the SLP 1 3/4" no AIRs and they are turning red and are really hot. Is this normal? It is hot enough to start melting the steering shaft rubber boot about 1 foot away from the firewall. Should I wrap the headers? I don't want to but I may have no choice. They are not coated and I really like the looks of stainless, so I could use some help.
Old May 6, 2002 | 09:43 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
No, that's not normal. They will get hot but they shouldn't be glowing red. Is the motor running right? I know that if the timing is off or if your running lean, the headers can start glowing. Also, I would not recommend wrapping the headers. There are too many negatives to doing it.
Hope that helps!
Old May 7, 2002 | 11:01 AM
Beefy89's Avatar
You are most likely running lean..
I would start by checking the o2 sensor.......
Old May 8, 2002 | 02:31 AM
titeride85's Avatar
Check your cat. My blazer had a plugged cat and my exhaust manifolds were glowing red hot. And yes. It will melt the rubber!!! And if it is the same line as mine(clutch), it will start a nice fire.
I would say check that first then see if you are too lean.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
