put new cat back and now every time i go over a pump it makes a scraping sound ??
Old May 9, 2002 | 08:06 AM
NEOMASTERZ28's Avatar
Car: 85 z28
put new cat back and now every time i go over a Bump it makes a scraping sound ??
i just put a new cat back 3in I pipe and 80 ser Flomaster and some chome tips now every time the back of the car goes down it makes a stomac twisting sound but when i check for any damaged parts there is no sign of damage .
so i have to be like a ***** and go over bumps slow any help or comments > >>
85 z28 305 tpi
Old May 9, 2002 | 11:51 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
It could be a hanger that is loose and is rubbing on the pipes or frame. It it possible that you wouldn't see any damage underneath, but you would hear a really bad sound. You might want to check to make sure everything is tight and welded together and nothing is rubbing.
Old May 10, 2002 | 11:07 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I had/have the same problem. The 3" exhaust does hang down a little lower towards the middle of the car, at least on the ones that I have seen. I have scraped mine up pretty good since I got it. I know what you are saying though about not seeing any damage. I was hitting the pipe that comes out of the Cat, but when I looked under there, nothing appeared to be damaged. After a while, and when I got under there and changed my oil on day, I noticed that is where I was hitting. I have just learned to go a bit slower over bumps, and sometimes angling over a bump to prevent that from happening. I hope that might help you.
Matt
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
