header primary size question
Old May 24, 2002 | 11:17 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
on a built 355(400 flywheel hp) how mush increase will i see going from 1 5/8" primary to 1 3/4" primary hooker super comp headers? the exhuast will also be going from true dual 2.25" and flowmaster 3 chamber to 2.5" with a x-pipe and flowmaster 2 chambers at the same time. this is all on a 1971 elky, so no cats?
Old May 25, 2002 | 12:09 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You'd gain some horsepower but lose some torque.
Old May 26, 2002 | 12:11 PM
c'mon
ttt
Old May 26, 2002 | 01:33 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Air pump
Do any of you know what that means? An engine is nothing more that an air pump. "If you can't get it out you can't get it in"
Does that make any sense to any of you?
Any time you increase air flow, you increase HP & TQ. The only thing you lose is back pressure. If you don't think so, find and read any dyno tests and try to understand what you are reading.
It may move the output around but you don't lose.
Some of you keep spreading these myths around and never stop to think what you are saying. It's all about combination and tuning.
End of rant,
Good day....
Don>>>
Old May 26, 2002 | 06:16 PM
Re: Air pump
End of rant,
Good day....
Don>>>
i know, i know. i was just looking for some estimates on the power gain. okay?
Old May 27, 2002 | 12:19 AM
IROCFAST's Avatar
I agree it makes some difference, and technically you do not loose any TQ, but it may move the TQ where you do not want it on the street. In most magazine comparo's between 1 5/8 and 1 3/4 headers on built small blocks the gain is marginal. My car makes about 430 rwhp and I run 1 5/8 headers. I may switch someday but am happy for now.
Old May 28, 2002 | 01:00 AM
bluemeanney's Avatar
hp and torque
that really isnt true. meaning, if the torque is moved so high up in the rpms you may actually ever get it back. just like an intake, you can move the power band up to a point where you may never actually see it, actually losing power. and actually the collector lenght would play a more important role unless you were right at the edge of power for the 1 5/8 headders. i would look at your hole system first before you mess with the headders.
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
