How would YOU.....
Old Jun 6, 2002 | 01:18 AM
tpi_roc's Avatar
How would YOU.....
How would you do this?
I've got an SLP Y-pipe hanging under my car, and a hooker cat back...
I'm trying to figure out how i wanna pipe it from the Y-pipe to the I-pipe. Im getting a 3" piece of pipe bent at a 45° angle and I think on the I-pipe side I'm going to weld on a 3bolt triangle collector flange, and do the same to the bent pipe, but for the Y-pipe side I can't decide if I should Pipe spread and slip fit it then weld, or if I should Butt weld it so that If i ever need to change anything I dont lose 2+ inches of the pipe due to the welded slip fit.
How have other catless guys taken care of such situations?
Old Jun 6, 2002 | 01:43 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I just cut the cat off, with the flanges, and welded a piece of 3" pipe in place of the cat. No bending or anything. If I need to change it in the future, then I'll worry about it then.
Thats the benefit of having a very hot wrench, cut the pipe if you need to.
Old Jun 6, 2002 | 01:50 AM
tpi_roc's Avatar
The SLP cat back doesn't end with a flange
And the Hookers flange is the "square" style, so that has to go.
So i've got a flangless end, and another end i think im going to go with the triangular collector style flange
Anybody elses setups?
Chevykid810
Jul 28, 2019 12:43 PM
1nastygta
Jan 16, 2014 10:41 AM
irocdls1
Jul 29, 2013 01:34 PM
karl's-92'-z28
Exterior Parts Wanted
Sep 22, 2010 12:27 PM
jamieriplilb
Interior Parts Wanted
Jun 29, 2009 02:04 PM
