Throttle Body vacum Tpi
Old Jul 28, 2013 | 10:44 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
I have an 1984 Camaro That had a 4 Cylinder Standard that i converted to A 305 Tpi . There is a vacum that is on the throttle body under the pcv port could i just cover this port with a cap . I think it goes to the canister but i dont have it will it affect anything if I do cover it.?????? Please help and Thank You.....
Old Jul 28, 2013 | 10:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Throttle Body vacum Tpi
vaclinesformyiroc.jpg?t=1325217059
Im not sure how you are venting you tank , but that line is from the ccp.
Old Jul 29, 2013 | 01:27 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
So the bottom one that had.vavum goes to the ccv... If so i got them backwards..??? Thanks again...
Old Jul 29, 2013 | 01:34 PM
Engine: Lb9
Transmission: M20
The bottom one is marked A ( Ported vacuum)This goes to the egr solenoid and tank pressure control valve.
Port C on the rh side of the TB is manifold vacuum to the purge solonoid.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
