2 flowmaster mufflers?
Old Jun 20, 2002 | 12:23 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
is it possible to fit 2 delta flow 40's under our cars and still run the pipes? if i done that would it be too loud (i have never heard them before) I wanna run dual exhaust but haveing a hard time deciding on mufflers.. engine: carbed 350 480" cam
Old Jun 21, 2002 | 12:07 PM
jd13's Avatar
Actually I'm running duals right now. They should be able to fit. I play on buying two 40 series delta flows very soon. Just gotta find a shop that will do what I want.
Old Jun 21, 2002 | 11:52 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
You could run the Flows corvette style where they both are under the rear bumper and the exhaust exits straight out the muffler. That gives you the best under car clearance. Then run the pipe down the driveshaft. That is how the true dual in my garage is setup except it uses these racing mufflers instead of Flows.
Old Jun 22, 2002 | 01:09 AM
xaivior's Avatar
Car: Camaro
Engine: 355
hey I've never thought of stickin them under the bumper ..cool that way I could get the mufflers i really want ..WARLOCKS!!!
whooo hooo!!!!! thanks for the idea man!!!
Old Jun 22, 2002 | 02:06 AM
trans87's Avatar
No prob man. That is the best setup for ground clearance and if you don't want to go with dumped. There is quite a bit of room under the rear bumper.
FormulasOnly
Jul 23, 2018 08:47 AM
Night rider327
Oct 9, 2015 09:25 AM
