center in/center out muffler possible?
Will there be enough room for a center inlet-center outlet muffler if the cat-back exhaust pipe is kept in the stock location. Now the pipe enters at the rear passenger side and the two outlets are in front. I'd like to be able to use most of the stock hanging locations and don't want to hack my nice 3" pipe up. Will the center/center muffler be mounted too far back? anybody with this setup?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I'm kind of confused on your exhaust setup but you should be able to go to a center/center muffler since it sounds like it hooks up in the stock locations. That's what I have on mine, but it's also a 4 inch system.
